Displays LACP, or dynamic link aggregation, settings for the specified LAG.
group-id |
Specifies the LAG group ID you want to display. This is the number of the port you configured as the logical port of the LAG. |
detail |
Show detailed information. |
N/A.
Identifies the particular LAG. This number comes from logical port assigned to the LAG and is the LAG group ID.
Shows the system priority for that LAG.
If this number is lower than the number displayed for the Partner Sys-Pri, the system you are working on is the controlling partner in the LAG.
Automatically generated LACP key.
Identifies the MAC address for the system connecting to the LAG on the remote end.
Shows the system priority for that LAG on the remote end.
If this number is lower than the number displayed for the Actor Sys-Pri, the system at the remote end is the controlling partner in the LAG.
LACP key automatically generated by the system to which this aggregator is connected.
If this number is lower than the number displayed for the Actor Key, the partner system is the controlling partner in the LAG.
Identifies the number of ports added to the aggregator for that LAG.
Member port
Port priority
Idle.
Initialized.
Current—Receiving LACP PDUs.
Expired.
Defaulted.
Selected—Ports with a matching admin key on the remote end.
Unselected—Ports that failed to meet with a matching admin key on the remote end.
Standby—Ports that exceed the number of ports that can be active in the LAG simultaneously. These ports can be moved into selected mode if one of the currently selected ports in the LAG goes down.
Waiting—Selected port that is waiting for LACP to determine if it can join the aggregator.
Attached—Ports ready to be added to the aggregator.
Collecting-Dist—Ports that are added to the aggregator and are transferring data.
Detached—Ports that cannot be added to the aggregator.
A—Activity.
T—Timeout.
G—Aggregation.
S—Synchronization.
C—Collecting.
D—Distributing.
F—Defaulted.
E—Expired.
The operational value of the port number assigned to this link by partner.
Up—Yes or no.
Enabled—Yes or no.
LAG State—Up or Down.
Unack count.
Wait-for-count.
Current timeout.
Activity mode.
Defaulted action.
Receive state.
Transmit state.
Minimum Active—The minimum number of active links that must be up for the trunk to remain up.
Selected count—Number of selected ports in the LAG.
Standby count—Number of standby ports in the LAG.
S—Displays information on controlling partner of LAG.
T—Displays information on controlled partner of LAG.
The following command displays information on the specified LACP LAG:
show lacp lag 4:9
The following is sample output from this command on a switch:
Lag Actor Actor Partner Partner Partner Agg Actor
Sys-Pri Key MAC Sys-Pri Key Count Mac
4:9 2110 0x0fa9 00:04:96:10:33:60 2110 0x0fa9 16 00:22:33:44:55:66
Port list:
Member Port Rx Sel Mux Actor Partner
Port Priority State Logic State Flags Port
4:9 300 Current Selected Collect-Dist A-GSCD-- 4009
4:10 301 Current Selected Collect-Dist A-GSCD-- 4010
4:11 302 Current Standby Detached A-G----- 4011
4:12 303 Current Standby Detached A-G----- 4012
4:29 200 Current Selected Collect-Dist A-GSCD-- 4029
4:30 0 Current Selected Collect-Dist A-GSCD-- 4030
4:31 202 Current Selected Collect-Dist A-GSCD-- 4031
4:32 203 Current Selected Collect-Dist A-GSCD-- 4032
8:7 101 Current Selected Collect-Dist A-GSCD-- 8013
8:8 10 Current Selected Collect-Dist A-GSCD-- 8014
8:9 9 Current Selected Collect-Dist A-GSCD-- 8015
8:10 8 Current Selected Collect-Dist A-GSCD-- 8016
8:11 7 Current Selected Collect-Dist A-GSCD-- 8017
8:12 6 Current Selected Collect-Dist A-GSCD-- 8018
8:13 5 Current Selected Collect-Dist A-GSCD-- 8019
8:14 3 Current Selected Collect-Dist A-GSCD-- 8020
8:15 0 Current Selected Collect-Dist A-GSCD-- 8043
8:16 3 Current Selected Collect-Dist A-GSCD-- 8044
8:17 2 Idle Unselected Detached -------- 0
8:18 37 Idle Unselected Detached -------- 0
8:19 36 Idle Unselected Detached -------- 0
8:20 35 Idle Unselected Detached -------- 0
Actor Flags: A-Activity, T-Timeout, G-Aggregation, S-Synchronization
C-Collecting, D-Distributing, F-Defaulted, E-Expired
The following command displays detailed information on the specified LACP LAG:
show lacp lag 5 detail
The following is sample output from this command:
Sys-Pri Key MAC Sys-Pri Key Count MAC
5 0 0x03ed 00:04:96:52:5b:a3 0 0x03ed 4 00:04:96:52:5b:98
Enabled : Yes
LAG State : Down
Unack count : 0
Wait-for-count : 0
Current timeout : Long
Activity mode : Active
Defaulted Action : Delete
Receive state : Enabled
Transmit state : Enabled
Minimum active : <3
Selected count : 2
Standby count : 0
LAG Id flag : Yes
S.pri:0 , S.id:00:04:96:52:5b:98, K:0x03ed
T.pri:0 , T.id:00:04:96:52:5b:a3, L:0x03ed
Port list:
5 0 Current Selected Attached A-GSCD-- 1005
6 0 Current Selected Attached A-GSCD-- 1006
7 0 Current Unselected Attached A------- 1007
8 0 Current Unselected Attached A------- 1008
This command was first available in ExtremeXOS 11.3.
Support for the LAG State and Minimum active parameters was added in ExtremeXOS 15.7.1.
